Hole table ordering
i have a large hole table that i'd like to re order from largest size to smallest.
how can i achieve this
MagRiz
(ST9 User Est 01.18)
3 REPLIES 3
Betreff: Hole table ordering
Hi @MagRiz
You are talking about a hole table in a draft?
Wolfgang
yes
MagRiz
Hi @MagRiz
the correct option setting should help You and bring the wanted result:
Wolfgang
