Holes Database
Hi guys,
We use ACME Thread in some of our projects.
With ST5, it was easy to add the data in the TXT file.
But with the Excel file in ST7, I add lines but I can't find these new features I create in the holes option menu.
Anyone know how to solve this issue?
I already tried the converter and no... It is not working
Thanks for your time,
Alex
Good Marketing makes the company look smart.
Great Marketing makes the customer feel smart.
Re: Holes Database
Hi Alexandre,
Attached, you will find my ANSI Inch.xlsx file with added ACME thread (at the bottom of the tab "Threaded").
(L'onglet "filetage" je crois pour le fichier en français).
It works fine for me.
Don't know if this is required for Solid Edge to re-read the file but usually, when I modify holes database .xlsx files, I close and restart Solid Edge just to be sure.
Michel Corriveau
Re: Holes Database
Merci Michel, ça fonctionne parfaitement.
Alex
Re: Holes Database
Siemens Genius Siemens Genius
Siemens Genius
"Don't know if this is required for Solid Edge to re-read the file but usually, when I modify holes database .xlsx files, I close and restart Solid Edge just to be sure."
I am fairly sure that after any change to the database files the hole command must be restarted for the file to be re-read.  It should not be necessary to restart Solid Edge.
Steve
Steven Sheldon
Advanced Applications Engineer
Siemens PLM Software
* Opinions expressed are my own.
