Holes in a Multi-body part
Hi, am I missing something or is it not possible to put a hole through multiple bodies in a MBP?  We're on ST8 MP12.
Guy
CAD/CAE Manager
ST8 MP12
3 REPLIES 3
Re: Holes in a Multi-body part
You can't do that in ST8 but you can do it in ST9.
Thanks, at least that stops me looking for a solution. We'll not be going to ST9, will have to wait until ST10 then for this functionality.
CAD/CAE Manager
ST8 MP12
So I've instructed the user to create a new construction body for all the 'holes'. These are solids which he can then 'subtract' from the other bodies to make the holes. Works Ok as the holes are simple through holes.
Guy
CAD/CAE Manager
ST8 MP12
