Re: Hotkeys for switch draft sheets up and down?
Honored Contributor
Honored Contributor
After about 100,000 hours of use. YES, it is that painful.
Some projects required use of those hotkeys over 500/hour
Unlearning something I have used over 1 million times is hard.
[quote]Maybe it would be easier to name softwares that do have this hotkey function. I don't think Acad does, Draftsight doesn't, even Excel doesn't as far as I can tell. SolidWorks, Creo, etc.?[/quote]
Just tested in autocad 2016, the hotkeys "Ctrl+PageUp" an pagedown worked perfect.
Solid Edge 2020 & AutoCAD 2020 user
