How I can install Standart Parts Administrator?
I use Solid Edge ST10 Student Edition.
This installer (https://www.plm.automation.siemens.com/plmapp/se/en_en/online/Shop#ACTION=1672944134) does not have it. It activate trial licence in every launch. Besides, I don't need trial version, I need student edition.
6 REPLIES 6
Re: How I can install Standart Parts Administrator?
Sign up for the Student Edition here:
https://www.plm.automation.siemens.com/plmapp/education/solid-edge/en_us/free-software/student
This however still will not give you Standard Parts.
If your school has an Academic version of Solid Edge, then your instructor should be able to assist you with providing a copy of Solid Edge along with Standard Parts.
i loaded the student edition from your link.
and now i want to install standart parts administrator. my school hasn't the academic version. i haven't dvd with solid edge. only pc and internetSmiley Happy how i can do it?
Hi there @AlexanderM,
In that case, you are not able to obtain it.
In my opinion, your BEST option would be to convince your school to get in contact with the local Solid Edge reseller, in order to set them up with a full academic install at their site, unlike the "Student Edition" install currently being used.
Hi @SeanCresswell,
unfortunatly it's impossible
Hi @AlexanderM
Hi @SeanCresswell
IMHO the Standard Parts Admin should be with student version too.
The SP Admin can be used for defining Your own standrad parts.
The SP library needs a Classic license at least or the University Academic license
The SP admin should be found on the standard installation image
Wolfgang
Hi, @hawcad!
Thank you for your answer. I'm agree with you. But it is not. In Solid Edge support I was advised to contact the University administration to purchase the academic version too. But now it is impossible. I found a way out. I download CAD files of standard parts from Tracepartsonline. Not very convenient, but it works. In addition, there are huge libraries from different manufacturers. Recommend!
All thank you for answers here!
P.S. Apparently, this can be considered a solution to the problem
