How To Draw The Countersink in 3D
Could you please tell me, how to draw the countersink in 3D..? Countersink means only Angle and Depth.. (For Ex. 120ª and 1.8mm Depth). Attached files are for your reference.. Please habe a look.
Thanks in advance,
RAY
RAY
Re: How To Draw The Countersink in 3D
Hi @JCIndia
Try the following settings in the hole operation properties:
Hole Properties.PNGHole Properties for only countersinkMaybe you have to change the hole diameter depending on the depth desired.
Sorry for my Spanish UI.
Héctor Pelayo Izquierdo
Engineering Department, JAE Ingeniería y Desarrollos, S.L.
Solid Edge ST9 MP5 | NX 9
Development: VB.NET
@Hector
Thanks you so much.. Its working fine for me..
RAY
RAY
