How can I download solid edge on my home computer using my license at work
Hi there,   Consult your VAR about obtaining an "At Home...
Esteemed Contributor
Hi there,
Consult your VAR about obtaining an "At Home License".
Also, here's some info on doing this yourself, if you have access to all the relevent information...and such is applicable to your site.
http://allyplm.com/knowledgebase/2013/4/2/how-to-get-a-home-use-license-for-solid-edge
Re: Hi there, Consult your VAR about obtaining an "At Home...
what is the difference between DXF-, STP-files generated by Home Use License?
Are they fully functional or is it necessera to open these files and re-save them per the floating license of the network?
It could be helpful if necessera we shoud do some work without the Travel License because of it's short time availability -30 days- .
Yasser
YD wrote:
Hi there,
There is no difference......the installed system and capabilities is the same [albeit a "Vanilla" install...you'll need to duplicate any customizations to get the same result as your work system] it is only the licensing that is different.
Thanks Sean,
Delivering for example DXF-, STP-Files generated with Home Use License to Customers could not be problematic?
Just Drafts would have the Watermark, that could be avoided with open in save them withing the physical network.
Yasser
YD wrote:
Thanks Sean,
Yasser
Yes, just the draft is the only output affected by the licensing.....the neutral formats are exactly the same as the commercial licence.
