10-04-2013 08:40 AM
In Solid Edge when I have a big assembly open and i need to find a piece that i only know the name, how can I find it in the Pathfinder?
Solved! Go to Solution.
10-04-2013 09:18 AM
On the Edgebar you should have a Select Tools pane that provides the ability to quickly search for a string across the parts in the assembly (Quick Query) as well as you can set up saved queries that are more advanced. Just remember to right click over the Quick Query field to set the correct property it is to search through or you may not get the desired result.
09-27-2017 03:05 PM
