How can I get my Draft file properties to inherit the properties of the part model?
Innovator
Innovator
A few years ago....well, more than a few years ago, Barham Software offered up an add-in that allowed a user to automate some simple processes.  The name of it is TreadTools.  Problem is it hasn't been updated and Solid Edge no longer recognizes it as an add-in.  I really liked the part of it where the draft file inherit the properties of the part model.  Is anyone out there doing this currently?  We are copying and pasting right now while in property manager.  But if we could get it to do this with as little input from the user as possible, it would be great.  We are currently on ST10.
Thanks!
Brian C.
15 REPLIES 15
Betreff: How can I get my Draft file properties to inherit the properties of the part model?
Hi @BrianC
I believe there is a similar tool by a German partner.
I will try to find it and post the link here.
Wolfgang
Hi @BrianC
You should try following link
http://www.incobase.de/download_soft/AcCpyProps_V100.zip
As You can see it is one of modengs (we still remember and always will do) macros.
I have not tested it with a current version of SE.
Wolfgang
Innovator
Innovator
Hi @hawcad!
Thanks for finding that. I will check it out and let you know how it works.
Brian C.
Could this Barham tool not be working because he needs to install view and markup to get the 32 bit bits of code.?
Bruce Shand
Innovator
Innovator
@hawcad,
I tried installing the add-in but no luck.  After I ran the executable, I rebooted and started SE.  The only thing that shows up in the "Add-in" dialog box is my 3D input device. Maybe its something I am doing during the install?
Brian C.
Innovator
Innovator
Hi @bshand
So maybe I need to install view and markup?  I don't think its available with ST10, is it?
Brian C.
I got it from the Siemens website. https://download.industrysoftware.automation.siemens.com/
Courtesy of @uk_dave from another thread.
Bruce Shand
Innovator
Innovator
Thanks @bshand.  I'll give it a shot.
Brian C.
Re: How can I get my Draft file properties to inherit the properties of the part model?
TreadTools stopped working when 64-bit came along. I contacted them a while ago and they chose not to update it. When I was at Robbins, I had a new add-in created to replace that same functionality. Tread Corp has since bought a copy of that tool from the same developer to replace their old TreadTools add-in. I don't know of anything free that will do it. I can contact the developer to get some details on the add-in if you want it.
Jamie
Jamie Griffis | Teamcenter Architect | Applied CAx, LLC
