How can I rotate this sketch around the Z-axis?
I tried to use steering wheel but i can only rotated it around Y Axis.  So I want the highlighted sketch to rotate 90 degrees around z axissteering wheel.png
5 REPLIES 5
Re: How can I rotate this sketch around the Z-axis?
Hi @Aeroeng
Please use the combination of the Shift + the plane inside the Steering Wheel to rotate it.
regards,
Arek
I tried to do it but I couldnt rotate it. do I have to click on the arrows? wheel only rotates the sketch around the y axis
As above. Shift+click the plane inside the torus of the steering wheel. This will flip the SW and allow you to use the torus to rotate about Z
CAD/CAE Manager
ST8 MP12
Hold shift and click the circular planar thingy.
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
Bruce Shand
Hi @Aeroeng
take a look into the info file (You will found it on the installation image of every Solid Edge DVD, called QRC.pdf)
Here You get best info on two pages regarding STeering wheel and live rules
Wolfgang
