How can i install ST5 on VISTA?
Siemens Creator
While I install ST5 on windows VISTA with SP2, but I get the error message: C:\windows\system32\MSVCR100.dll couldn't run on this windows.
Could you help me to solve this problem?
Hi there,   System requirements for ST5 state a minimum o...
Hi there,
System requirements for ST5 state a minimum of Vista "Business", or "Enterprise" versions....is this a "Home" version? In which case your only option would be to upgrade to Windows 7, or 8.
Testing: Solid Edge 2019
Re: Hi there,   System requirements for ST5 state a minimum o...
Siemens Creator
Yes, this is windows VISTA home version. Do we have workround to install on it? because this customer want not to upgrage windows.
None that I'm aware of.....sorry.
Siemens Creator
OK, I know, thanks you!
