How do I check the air flow through an assembly such as an air duct.
Builder
Builder
I have a large manufacturing oven with an air duct system in the ceiling. The air flow needs to be divided at one end. I am wondering if there is a way to check how much air is traveling which direction with the positioning of my baffles.
You would need to use CFD analysis software to do this su...
You would need to use CFD analysis software to do this such as Ansys Fluent/CFX, FEMAP with the Maya flow solver,CFDesign, etc...
Production: ST10 MP7
Testing: SE 2019
http://Grundey.blogspot.com
Moved:
ESI Group is a Solid Edge Partner that has CFD software W...
MLombard
Retired
The community does not allow promotions from sales partners. We welcome technical solutions such as "Have you tried CFD?"
