How do I install an Live Linking Add-In in ST6 for Keyshot 4. My machine is 64bit.
Hi,   You should download it from here: http://keyshot.co...
http://keyshot.com/downloads/plugins/
And install it (next, next...)
BR,
Imi
Imics
Re: Hi,   You should download it from here: http://keyshot.co...
Tried all options, Keyshot indicates live linking is running with a tick but model data is not updated from Solid Edge. I've reverted to the translate with .BIP format.
What kind of Keyshot version do you use? Trial?
BR,
Imics
Imics
We use Keyshot version 4.3.10 running from a floating licence and on a Dell precision PC (64bit) 10 gigs ram. Solid Edge is ST6 version 106.00.04.03
[Description: signature block 1]
