How do I save my personal settings to the network and get them on another computer?
7 REPLIES 7
Betreff: How do I save my personal settings to the network and get them on another computer?
Hi @JustinMc
You will find an application under the Solid Edge program entries for saving and restoring Your settings and preferenes.
I can not tell You what the original and correct English name will be but look under the Solid Edge group for "Settings and Preferences Wizzard"
This will allow You to save Your settings and preferences (files for user interface and templates)
Further You can do it the old fashioned way, we did before this tool was created, You can export Your Current User Settings of the registry and import it on the second computer.
Wolfgang
Re: How do I save my personal settings to the network and get them on another computer?
@JustinMc Use the "Settings and Preferences Wizard" found under the Siemens Solid Edge start menu area.
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
Hi @KennyG
this time a was 20 seconds ahead!
Smiley Wink
Wolfgang
I read that somewhere but I can not find that Preference Wizard.
Hi @JustinMc
I only can show it to You with the German Windows interface:
But this should lead You to Yours.
Wolfgang
Thank you, something that simple was driving me crazy.
The English version...
If you do not have this menu then confirm your Solid Edge version as the Settings & preferences wizard is a fairly new addition.
