How do you change the scaling in 2d V2?
N/A
How do you change the scale? I need to do a drawing that is larger than page size
and can't figure out how to change the scale.
Also the tutorials won't run, says there has been a problem with the menu.exe
Any help would be appreciated.
Re: How do you change the scaling in 2d V2?
N/A
Ron,
You draw on the model sheet at 1:1 and then scale the drawing when you place it
on the drawing sheet. Is that what you are looking for?
Ed
>size
