How do you get your PMI dimensions to show up on the draft
Mervin D. Yoder
CAD | Designing
keimlumber ST9
You can use Retrieve Dimensions in Draft to pull dimensio...
You can use Retrieve Dimensions in Draft to pull dimensions from the model into your Drawing Views.  Alternatively, you can set up a PMI Model View and specify that when creating your Draft views.
http://Grundey.blogspot.com
Re: You can use Retrieve Dimensions in Draft to pull dimensio...
Thank you Ken, now I try to use it on an ISO view but it seems it doesn't work on an ISO
Mervin D. Yoder
CAD | Designing
Millwork Specialty
[cid:image001.jpg@01CEC668.9E23AE40]
Phone:330.893.2251 Ext.339
www.keimlumber.com
Mervin D. Yoder
CAD | Designing
keimlumber ST9
No, it does not. You might be able to use a Model View for an ISO though.
OK Great, Thank you Ken
Mervin D. Yoder
CAD | Designing
Millwork Specialty
[cid:image001.jpg@01CEC66F.198E51B0]
www.keimlumber.com
Mervin D. Yoder
CAD | Designing
keimlumber ST9
Do exist any way to show up PMI dimension in draft via VB.NET code ?
