Re: How do you remove the border around text and bitmap images
Actually, neither the writing or the .png show up as lines to cut in cam software.
I always used the insert text, like you were in the beginning, and I had to take images and vectorize them into a dxf to add to my part as a sketch. Google for free vectorize, and you should find something that will work. This allowed my dxf to have the added text and "image" I wanted to come through for my fabrication machines.
As I said before, you have to unblock the text, and the image, if they come into your CNC software as one block.
Hi guys.
Is there a way to set the border offset.  The default setting is '0'.
I want it to be 0.5
Darren
