How does Solid Edge works with Gerber Files? Its there any addon that works with Solid Edge?
Hi All,
Help needed as I need to work Solid Edge with Gerber file.
Is there any add-on that allows Solid Edge to import Gerber file?
Tang Chee Sang
I'm assuming you are trying to create a 3D printed circui...
Esteemed Contributor
I'm assuming you are trying to create a 3D printed circuit board with component footprints and height... I know of a product called PCBto3D that does this for Solid Edge but I believe you need the more standardized 'IDF' file format.
http://myplace.frontier.com/~tldi/
I also found this product that does convert Gerber to CAD...
http://m.plm.automation.siemens.com/en_us/Images/5208_tcm1224-4951.pdf
Production: ST9 MP10
Testing: ST10 MP3
Re: I'm assuming you are trying to create a 3D printed circui...
Hi Grundey
You can please help me!
I using PCBto3D trial on the SolidEdge, but I can't import gerber file into SolidEdge
You can sent guide file to me by pdf or video
My Email: mrbuitu@gmail.com
Best Regard,
BuiTu
