How flatten this part? Weird.
Builder
Builder
I am trying to convert these parts to sheet metal using various methods and have had no luck. I need to to unbend each individual bend (1 bend is actually 2 bends with independent radii for one part). A simple flat pattern will not do. Please help. Thanks. This is such a wonderful community and a great resource for noobs like me.
Re: How flatten this part? Weird.
Builder
Builder
I got the -2 file flattened.
Here's part 1  flattened in ST7 MP7
http://screencast.com/t/gKRX2qvT
Builder
Builder
That is not what I am looking for. I am looking to unbend each bend independently, not as a whole. So, conversion to sheet metal is needed. Not flatten the entire part.
Look at this then...
http://screencast.com/t/DPsNWVxOJ8j
copy the top surface, use that to create an ORDERED contour flange...
then you can unbend and rebend...
tested this and works well
Builder
Builder
Ok, not sure how to create a contour flange from a surface in ordered. I know how in sync. Now, I tried what you did originally. First bend unbent great. Second bend unbends into nothing? I unbend it and it disappears, literaly. Not sure what would cause the differences we are having. Can I have the file you created?
Here you go...
Builder
Builder
Thank you so much. Do you have any clue as why the leg disappears for me and not for you. I did exactly as you did and this is what I get.
Esteemed Contributor
I also lose the leg.
Bruce Shand
