How many computers can I use the Academic License?
Hi All,
I'm hoping someone can help me. I had to repace the hardrive on my desktop and the OS on my lap top had to be reinstalled. Just as well because the academic version had expired. So I renewed it for another year and reinstalled the academic version of Solide edge.
SE assigned me a new Academic Code that I was able to install in my desktop at home and at work. However, the same code did not work on my lap top. So the question arises, how many times are we allowed to install the academic version of SE using the same activation code?
Thanks George
Re: How many computers can I use the Academic License?
Community Manager
@GMan56
Your Solid Edge academic code is registered to you and will work on any number of your machines, provided they are all running the same version of Solid Edge.  Your ST7 Solid Edge activation code will not work on your machine(s) running Solid Edge ST6, ST5, and so forth.
If your machines are running the same SE version as your registered activation code, then it sounds like something else may be going on.
I recommend you call GTAC, and they will help get you up and running.
Laura
Global Technical Access Center (GTAC) in North America are:
          1 800 955-0000 or +1 714 952-5444 (North America)
Monday - Friday 5:00 AM - 5:00 PM Pacific Time (US)
