How should we submit errors or omissions with Help and Tutorials?Found 1 in new Enclosure tutorial
PLM World Member Genius PLM World Member Genius
I wasn't sure how we should submit errors or omissions in Help and Tutorials.  Should it be through GTAC, the new Community, other?
I was doing the new Enclosure command which is part of "Creating a simplified assembly" tutorial.
http://support.industrysoftware.automation.siemens.com/training/se/106/en_US/en_US/selfPacedExt/spse...
There is an instruction that says:  "Set the enclosure shape to Outside Box"
This should be "Outside Cylinder".
Since it is a web page, I would guess it's a little easier and faster to fix these types of issues.
Thanks.
Carl Breving
S&C Electric Co.
Re: How should we submit errors or omissions with Help and Tutorials?Found 1 in new Enclosure tutori
The best way to notify us of problems is through GTAC - we monitor forums, but it's easy for us to miss things.  Thank you for pointing this out.
Community Manager
Great to see you using the new tutorials and ST6 functionality. A gold star for you! :-)
Dan Staples
