Re: Solution Center article 002-7002869 addresses this, cut a...
.dwg version is also available on GitHub
But to directly answer your question, yes, basically change all references from dxf to dwg.
-Dave
I was able to associate DXF and DWG to Solid Edge Draft with this utility:
http://www.nirsoft.net/utils/file_types_manager.html
(you can create a new extension like dxf and choose "Solid Edge Draft" association for it)
Is there a solution to this issue that does not involve having to modifying the registery?
See the post from @FredMenage directly above your question.
