How to Pattern by Angle in Ordered
I don't see pattern command by angle in Syn and Ordered
Please help me to use
Thanks!
Best Regard,
BuiTu
Re: How to Pattern by Angle in Ordered
On the Pattern Command Bar is an option called 'Fill' which allows specifying the angular spacing between pattern occurrences. Are you looking for some thing like this ?
I want to use in Rectangular pattern
Let me show you in picture bellow
Best Regard,
BuiTu
You perhaps mean staggered pattern by specifying angle of inclination.
This options does not appear to be supported in SE ordered.
EDIT: Sorry about not mentioning this is possible in Synchronous modelling.
Yes! Thank you!
I think Solid Edge need to improve this options in the future
Best Regard,
BuiTu
Further to the edit in my previous reply, I tried out the pattern in Synchronous and found the steering wheel can be used to specify an angle for the rectangular pattern:
Thanks Tushar
I will try to design in Syn and use your solution for Rectangular pattern
Best Regard,
BuiTu
Hi @BuiTu
Not sure if this is still relevant, but just found a simple solution for rotating pattern in Ordered too; see this video:
~Tushar Suradkar
fb.pngSolid Edge Users Facebook Group
