How to add Steering Wheel in Ordered Solid Edge ST9
How to add Steering Wheel in Ordered Sheet Metal for Solid Edge ST9
Shoud I put somewhere in options to show me this, I can't find it.
Please it is urgently
10 REPLIES 10
Re: How to add Steering Wheel in Ordered Solid Edge ST9
The Steering Wheel is Synchronous only.
Greg
The Steering Wheel is available when using Synchronous or Assemblies.
You Need it with ordered, so it's not possible.
But! If you start modeling with Synchronous & you Switch the Geometrie to Ordered, you will be able to use the Steeringg Wheel during ordered modeling so you have just to select a face/faces and it is there.
Yasser
Smiley Sad ..I have problem with angle
How do I change angle on one part ,here is example what I want
@YD wrote:
Yasser
Yasser,
In the scenario you described, the steering wheel will still only appear if the face you select is a synchronous face. It cannot be used for ordered faces.
Greg
I can't go in Synchronous because company work only in Ordered and it is fix on computer , so I can't change anything. I just tried but it doesn;t work,
Is there any other oslution to move part as on my example 1 .
I don;t want to use another plane, I know how to add another plane with angle, but this angle destroy mey head trying to find this all morning
1-If you have sketched all the sheet metal in ordered, so you have to go back to your sketch and "Edit" it.
2-But if you have additionnaly created the flange you have to go on it with the right mouse button and edit it "dynamically" and you'll see all the flange parameters inclusively the Angle that you have to change.
Yasser
Thank you so much
You're welcome Jasmin!
