How to angle face of a cylinder or tube in ST10
Any of you good people out there can assist me with an answer to this query, please.
8 REPLIES 8
Re: How to angle face of a cylinder or tube in ST10
Kind of need more specific information on what you wish to achieve. Are you talking about one of the two planar faces on a cylinder?
Solid Edge 2019
Windows 7 Professional
Nvidia K2200 & Intel Xeon
"You're doing it wrong"
Betreff: How to angle face of a cylinder or tube in ST10
Hi @John_7
suppose it is what @nominus38 asked and the simple answer is:
Select it with a mouse click and use the Steering Wheel to rotate it
Wolfgang
Hi @John_7
and here is a short video explaining what I mentioned before.
Wolfgang
Hi @John_7
and - if You look for an alternative solution to achieve the rotate face - You also can use the Draft Feature of Solid Edge
See video
Wolfgang
Hi - just the one planar face at one end of the cylinder tube. See attached sketch.
I can see Wolfgang has shown in his video exactly what you are illustrating in the sketch.
Was just about to watch Wolfgang's videos when I saw your notification pop into my Inbox. Thanks!
Thanks so much for your help, Wolfgang!
I need a bit more practice, but I achieved the result I was looking for.
