How to assemble Ball Bearing?
I tried to create a ball bearing, but I cannot assemble balls with ball support. (Please see the attached screen-capture.)
All assemble commands don't work with ball part...
Do you have any ideas?
mutyo051026
Hello mutyo051026                  There iare several way...
Hello mutyo051026
There iare several ways of doing this - the first and most simple is to use a Connect relationship to connect the two centers.
Another way is to use the creation planes or co-ordinate systems to locate the ball into the cup.
This video should make it clear.
(view in My Videos)
Cheers
Mark
Re: Hello mutyo051026            &n
Thanks, Mark.
I didn't know how to use connect command, so your advice was really helpful!!
