How to auto Baloons distance adjustment in SE Assembly?
Please find the attachment for detail
Here I don't want to hold and drag each baloon for distance adjustment and it going to more time
Suggest me someone if there is any option is available to do this auto task
3 REPLIES 3
Betreff: How to auto Baloons distance adjustment in SE Assembly?
Hi @lokesha
select the Alignment Shape object and change the option for "Minimum Spacing" according to the size of Your balloons.
Wolfgang
Hi @lokesha
did this solve Your problem now?
Wolfgang
yes, thanks for the solution
