How to bend sheet metal with a pattern in Sync
So i need to create a pattern on my sheet metal part prior to bending. As you can see in the video the bend feature fails. am i doing someting wronge?
(view in My Videos)
Nathan M. Gardner
https://www.etsy.com/people/NathanMGardner
Be sure to check out my work!!
Made in Maine Wood Carvings
Hi,   You have two ways!   1. RMB on pattern "feature" an...
You have two ways!
1. RMB on pattern "feature" and Break it before try to add plus bend!
2. You should go to order mode and Insert bend there! This is mixed mode! I suggest to use this!
BR,
Imi
Imics
Nathan, In case you are not familiat with mixed mode mode...
Nathan,
In case you are not familiat with mixed mode modelling this video should make it clear.
(view in My Videos)
Cheers
Mark
