How to change default text
N/A
Is there a way to eliminate or turn off word wrap as a global default with out going to each text item?
Re: How to change default text
No, you cannot globally set this.
I assume you are opening an AutoCAD file in 2D Drafting.
Do you know what font the AutoCAD file is using for the text.
When you open the file, there are options where you can map the fonts used in the AutoCAD file to fonts used in 2D Drafting.
This may help.
Rick B.
