How to change language interface of Solid Edge ST10?
Hi there, it is possible to change language interface of ST10 from Portuguese to English? I downloaded Trial version of SE but during the setup is not any possibility to change language.
Thank you!
Richard
Re: How to change language interface of Solid Edge ST10?
I believe that SE detects the language the OS is configured for and uses the same by default.
If you look on the Helpers tab of the Solid Edge Options, at the bottom there is an option to force SE to default to English.
Production: SE 2019 MP4, Testing: SE 2020
http://Grundey.blogspot.com
Thank you KennyG, it is work!
Richard
