How to change the Debugging level in Solid Edge
HI,
I would like to change the debugging level in Solid Edge ST6 and to set it to a lower logging level.
I would appreciate any help.
Thank in Advance!
Re: How to change the Debugging level in Solid Edge
can you expand a bit?
there are logging tools that can be turned on, but im not aware of turning "down" debugging.
can you explain what you mean and what you intent of doing so would be.
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
Hi Matt,
after uploading an assembley, the logfiles are showing large number of lines, so I think that the Debugging level is set to be High. So I thought I would change the level to gain performance.
Thanks in advance!
are you talking about a PDM system upload?
Teamcenter?
Matt Johnson
Teamcenter 10.1.7
Im talking about Solid Edge with linkage to Teamcenter
you will probably get more input from the folks on the TC ADmin forum...
https://community.plm.automation.siemens.com/t5/Teamcenter-Administrators-Forum/bd-p/Teamcenter-Admi...
Matt Johnson
Teamcenter 10.1.7
