How to change the layer of a dimension and a drawing view in Draft?
Is it possible to change the layer of a dimension and/or a drawing view in Draft?
Re: How to change the layer of a dimension and a drawing view in Draft?
Yes, just select the object you want to move layers on and then select the "Move Elements" button on the layers form and select the layer to move them to.
Production: SE 2019 MP4, Testing: SE 2020
http://Grundey.blogspot.com
Perfect, thanks!
