How to change the titleblocks for your own use
Not applicable
How to change the titleblocks, with your own name and date and so on?
Greating Willem Huizer
Re: How to change the titleblocks for your own use
Not applicable
Willem,
The geometry for title blocks and sheet borders are on a background sheet.
Click on View and then Background Sheets at the top of the application
window. This will enable the background sheets so that you can select them
to change the geometry.
A working sheet (Sheet1) uses a background sheet to display the border.
Right mouse click on Sheet1 at the bottom and then click on Sheet Setup.
This allows you to specify properties for the sheet. Click on the Background
tab in the dialog. This is where you specify which Background sheet to
display for the working sheet.
Rick B.
