How to colour a sub assembly
I'd like to add colour to my sub assembly. I know i can use part painter in the part space, but what about in an assembly.
Can i colour the whole sub assembly within an assembly, without having to open each part
thanks
MagRiz
(ST9 User Est 01.18)
Re: How to colour a sub assembly
Yes. If you select the sub-assembly and then go to the drop-down of 'View Style' in the Style group under the Home tab.
585 ST10 Win 7
Sorry, I meant 'Face Style' not 'View Style'.
585 ST10 Win 7
can you show me a screen shot please?
MagRiz
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
Bruce Shand
Hi @bshand
Do you also see the video as un-available in your last message?
I see this:
Do you think there is something you can do to make this video available?
Or should this be reported to @AmyReyes
If you still have the video offline, would it be possible to attach?
I am interested in knowing how to change the color of a sub-assembly.
Thanks.
~Tushar
I don't think I kept a local copy of it.
Bruce Shand
Hi there @MagRiz,
I have no doubt it answered the question, but I too can't see the video from @bshand, so I thought I'd drop one also.
(view in My Videos)
Thanks. Pretty sure you're rendition was more visually interesting.
Bruce Shand
Community Manager
Hi @Tushar @bshand
Off-topic from the original thread, but in reply to the video display issue, this can happen sometimes if you upload the same video more than one (whether you save/publish it or not) even if you accidentally hit the upload more than once when inserting the video if the file has the same name. Usually reuploading it with a different name with resolve the problem.
Amy
Community Manager, Solid Edge
Become a Solid Edge Certified pro today!
