How to control dimension or peer relation when create part in place?
Hi all;
I have some problem to control distand between center of new part(create part in place) and silhouette arc of part in assembly.
Please recommend.
- Control sketch?
- Control 3D?
Re: How to control dimension or peer relation when create part in place?
in such cases it can be helpful to have a plane in th part model that you can use to constrian at the assy level.  consider creating a plane in your part at the mid point of your arc.
Also be sure you have "Peers" turned on to locate peer geometry at teh assy level.
Matt Johnson
Solid Edge Certified Professional
Solid Edge 2019 (SEEC) - Production
NX12 (Tc Integration)
Teamcenter 10.1.7
Honored Contributor
Honored Contributor
What I do is make sketches that were created w/ the include command that maintains relations. If down the road you need to repair those relations, the include symbol gets deleted, and co-linear and other relations are used between one parts sketch and other parts edges.
