How to copy solid edge ST9 themes from one system to other?
4 REPLIES 4
Re: How to copy solid edge ST9 themes from one system to other?
A simple Copy-Paste should work.
On my system the themes are stored here:
C:\Users\<UserName>\AppData\Roaming\Unigraphics Solutions\Solid Edge\Version 10n\Customization\
Ya, thanks
The problem is > "Appdata" folder is hidden by system default
Now you can mark it as accepted solution.
Thanks.
Hi @lokesha
use "%appdata%" to go to that folder
Wolfgang
