How to create a cam channel along a cylindrical rod
As you can see that the it's possible to make the cut out but I have no way to make a smooth transition from the straight slot to the sweep section. Has anybody run into this problem before and come out with a solution? Any suggestion, idea..would be appreciated.
Thank you.
Re: How to create a cam channel along a cylindrical rod
Hi there,
You might find this thread helpful with your task here.....
http://community.plm.automation.siemens.com/t5/Solid-Edge-Question-and-Answer/Rail-cut-out-problem/q...
Solid Edge 2019 [MP8] Classic [x3 Seats - Cloud Enabled]
