How to create "internal" ligts in KeyShot
Edgers,
This morning I was asked by a colleague how to go about adding an interior emitting light INSIDE of a model in KeyShot.  Some of you may already know how to do this, but for those who don’t, I thought I would go ahead and share this brief PowerPoint I put together to explain how to do it.
Hope this helps someone out there!
Re: How to create "internal" ligts in KeyShot
Another example that I created in Solid Edge of an emitting light source in a robot assembly.vexlight.jpg
Example adding light sources to the windows to replicate sunlight.Addition.36.jpgAddition.37.jpg
Very helpful, thanks!
Community Manager
We liked Doug's PowerPoint tutorial so much, we asked him to write it up as a blog. You can check it out here: https://community.plm.automation.siemens.com/t5/Solid-Edge-Blog/3D-Rendering-Tutorial-How-to-Create-...
Figured that would make it easier to search for/share in the future. Awesome work, Doug!
