How to cut text in a part
I would like to know how to cut text trough a part?
I put some text on the part but i can't extrude it...
Could you guy's tell me how to do it?
Re: How to cut text in a part
Sketching tab of the Ribbon in the Insert section you will find Text Profile.  Use that to create the text sketch and then extrude it to create your cut.
Production: ST10 MP7
Testing: SE 2019
http://Grundey.blogspot.com
Thank you for your answer.
However, that's what i did. I have the text sketch on the part face but selecting it allow me to modify or move the text but i can't extrude it.
ok i found it...
I had to select the extrude too and use "simple" option to extrude it.
Thank you
Is there any fonts that have the letter attached?...   i mean if you want to cut domething like a D a P or O, you want the inner to be attached. or i have to manually attached it?
Look for "Solid Edge Stencil".
Testing: SE 2019
I found... solid edge stencil fonts do it
No that important but some parts of my assembly have originally been draw with solid works.  The imported part don't have the same color. Even after i edit it as steel.
the hole i did in the part have the same color of my assembly but not the original faces.
You'll need to use "Part Painter" to apply the "Steel" color, but make sure the selection filter is on "Body"...to override the "as translated" part color.
Solid Edge ST10 [MP8] Classic [x2 seats]
Is there any way to link the text to a custom property so that it will update when the custom property updates?
Terry Tyson
Software Automation Designer
