How to delete unused layers from Solid Edge Drafting in a single click?
Re: How to delete unused layers from Solid Edge Drafting in a single click?
Attached at the end of this tutorial is the macro you need.
Thanks  for your immediate response. Can you tell me for blocks too?
For blocks, it's here.
Solid Edge ST9 has a new command to delete empty layers.
http://Grundey.blogspot.com
Yes, I noticed that command in ST 9
Besides Blocks, users are also seeking purging dimension and face styles.
