How to extrude only one side?
I use Extrude command to make object on the surface of another ojbect, and after I draw the profile on the surfece and accept, they request to choose "non-symetric extent" or "symetric extent", and "through all", "through next", "from/to extent" or "finite extent".
But after I choose one side and enter the dimension, they ask me to enter the dimension of opposite side. But I don't need the opposite side.
So how can I choose only one side to make prominent object?
Well I assume you're in Ordered. Well look at this video...
Well I assume you're in Ordered. Well look at this video and see if this solves your problem. http://screencast.com/t/DQceOesYu Bob
Re: Well I assume you're in Ordered. Well look at this video...
After I changed to synchronous I was able to solve this problem. Thank you!
