How to extrude text on an ring?
I would like to extrude text on a ring.
I could wrap the sketch but than I don't know what to do...
Somebody who can help?
Thanks!
Solid Edge 2019 & AutoCAD 2019 user
Re: How to extrude text on an ring?
Community Manager
Use the Normal (perpendicular) Protrusion command.
Dan Staples
Thanks for this fast answer!
I knew the 'normal cutout', but never used this command.
Ok, so this works fast and easy but...
What I do:
  • draw ring
  • make parallel plane (tangent)
  • draw text sketch on parallel plane
  • Wrap sketch
  • Normal protrusion of the wrapped sketch (text)
When I change the text a bit (even only add a space between words) the normal protrusion gets corrupt  an fails to rebuild.
I don't think this is how this should work.
