How to fix this?
I drew a bended plywood form.
After that, I drew a block of foam, starting with a part copy of my plywood.
My protrusion of the foam is made with "Project sketch" with the option "Maintain associativity" ON.
After that I needed to change my plywood part, so the foam has to change automatically.
Apparently this happened, but with error:
You see all the lines are orange, so not good.
When I erase the "8 lookalike" symbols, the lines are blue again, but than the associativity is lost.
How to fix this best?
Now with parts (ST8)
Solid Edge 2019 & AutoCAD 2019 user
4 REPLIES 4
Re: How to fix this?
No idea why the errors (kinda have to "be there" or see it in person) but the sketch appears to me like you could delete the includes and constrain it with point-on, concentric and equal.
Bruce Shand
I'm not quite sure either but it's happened to me a lot over the years.  One trick I try is to delete the links as you did, but then turn around and undo the deletes.  Sometimes that works.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
Kyle,
Do you stand up to turn round or remain in your seat ?
Does one method work better than the other ?
Smiley LOL
HP Z420 16GB RAM
Quadro K4000
ST10 MP12 on Windows 10 Pro 64.
Beachcomber,
LOL!
I spin around a few times in my chair - enough to get dizzy and then try again.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
