How to get all unique part and sub assembly from main assembly in Solid Edge
I need count of all unique part and sub assembly of any Assembly file through VBA/VB.Net.
Ex. Let Suppose i have an assebly naming Assembly1. Assembly1 Contains both part file as well as sub Assembly file. Then,
Dim Count_Part As Integer  = count of unique part file present in Assembly1
Dim Count_SubAssm As Integer = Count of all unique sub assembly file present in Assembly1
Any help would be greatly appreciated.
Re: How to get all unique part and sub assembly from main assembly in Solid Edge
Hi:
The correct place to post this question would be the Solid Edge Developer forum.
Out there, start with searching existing solutions from the Search field at the top using keywords:
One such topic I found using 'count occurrences' is this one:
http://community.plm.automation.siemens.com/t5/Solid-Edge-Developer-Forum/How-to-extract-data-from-a...
Hope you find your answers in the thread.
~Tushar Suradkar
www.CADVertex.com
