How to insert Text on a draft?
I wanna insert text in the box located lower-right corner of a draft, and I used the command "Text profile (Sketchng tab > Insert box)" with Solid Edge ANSI font, but when I entered text in the box and clicked on "OK", the text appeared with double lines and a frame as shown by the attached image.
How can I fix this problem?
you are looking for "callout" or "text box"  you used tex...
you are looking for "callout" or "text box"  you used text profile.
Matt Johnson
Application Engineer
Ally PLM Solutions
matt.johnson@allyplm.com
http://allyplm.com/
Re: you are looking for "callout" or "text box"  you used tex...
Esteemed Contributor
Further to Matt's answer...in "Callout" you can have some feilds fill out automagically, using "Property Text", check the help file [F1] for more.
Solid Edge ST10 [MP3] Classic [x2 seats]
Thank you soooooooooo much!!
