How to insert an image on a background draft AND make its edition not possible?
Hi guys.
Sometimes, when I open some DWG files with images or labels on it, Solid Edge considers it just a 'smart frame' with the 'edit' option greyd. I suppose SE sees that just a simple plain image (or block).
How can we do that directly in Solid Edge Draft environment ?  Or, which image format I could choose to achieve that ?  (It needs to appear on printed paper, and also if I export the file to PDF, DWG, DXF, etc)
Thanks for help.
Hilario, Flavio
Industrial Designer
ST10 / Win10
