How to knurl cylindrical surface Solid Edge ST9 Synchronous?
Does anyone know how to knurl a cylindrical surface?
I'm using Solid Edge ST9 an I'm in Synchronous mode.
20 REPLIES 20
Betreff: How to knurl cylindrical surface Solid Edge ST9 Synchronous?
Hi @floresma
due to my non native English backround,
can You explain a little more in detail what You are trying to achieve?
Thanks!
Wolfgang
@hawcad Knurl is the term used for the diamond pattern (or other) texture applied for grip enhancement.   Typically applied by a pressing tool while the part is rotated in a lathe.
@floresma   there are 2 approaches based on your need.
1.) preferred (IMO),  do a split surface and simply add texture to the draft and use a call out to annotate the Knurling.
2.) Create a helical cut and pattern.  will need to do so CW and CCW.
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
Hi @Johnson_BigMatt
thanks for clarifying and Yes 100% with You that the usage of a texture onto the cylinder surface is IMHO the easiest and fastet way to show that.
Gracy point about this issue:
I just explained that last week to a customer asking me exactly that question - but not in Englsih!
My thoughts went into the "twist" direction rather than "knurl"
Wolfgang
Thanks for the feedback everyone.
Does anyone know of a good resource with instructions on how to work with cylindrical surfaces?
Hi there @floresma,
Is this "texture" version enough, for what you want to do?
Hi @SeanCresswell
Hi @floresma
and if You give the texture a structure too (using the same picture in black/white/grey) You even will get a more realistic 3D feeling with a high quality view.
Wolfgang
Absolutely @hawcad...., it is ALL about the quality of the image used for the texture, in order for it to be suitable for the task.
That particular texture was the only one I had available, as used for a custom bronze fastener we produce here. Just enough visual information for manufacture. Robot Happy
@hawcad wrote:
Hi @SeanCresswell
Hi @floresma
What do you mean by structure?
Bruce Shand
If you are looking for a visual representation, check out the capabilities of Keyshot which you can run right out of Solid Edge.
https://www.keyshot.com/forum/index.php?topic=13862.msg69765#msg69765
https://www.keyshot.com/forum/index.php?topic=768.msg2935#msg2935
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
