How to make a dome?
Hola ST community!
I would like to make a dome from a circular sketch/face. Is there any way to do it. Like in solidworks we can define the height of the dome and it will make a dome from that height tangent to the base of the circle.
Re: How to make a dome?
You can revolve a profile to create a dome shape, but AFAIK there isn't a separate command specifically for creating domes.
HTH,
Jason
Yeah, I also was thinking it that way, but it´s still two steps further then just using a dome command. Thanks anyway.
Honored Contributor
Honored Contributor
In sheet metal, you could add a dimple.
I suggest using BlueSurf command or Bounded surface to making Dome.
Here is a video:
BR,
Imics
