How to make planes on Solid Edge
I am make  top plane for this  part: see attach
Re: How to make planes on Solid Edge
What's the question?
Bruce Shand
ST10 MP7 - Insight - Win10 - K4200
Do you want that side to be the top plane in a drawing or are you trying to re-orient the part in the model?
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
Honored Contributor
Honored Contributor
The simple answer is to offset parallel planes realtive to the Default planes of the part file.
The other commonly used answer would be to use an object plane or a parallel offset to an object plane.
When you are creating the view for the drawing, there is a drawing view layout button that looks like a miniature drawing.  Click it and you can select default orthoganal views or you can click on the "custom" button and rotate the model around to select whatever face you want.
Another option is to place the view (even if it's not the one you want) and then use the "principal view" button in the ribbon bar to create orthogonal views until you get the one you want.  Then delete the unwanted views.   I find that faster sometimes.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
