Re: How to make this drawing to 3D?
Hi @mo333
first of all let me say, that it looks real strange for us to see Your Japanese letters and signs.
Great, would be fine to understand those.
OK.
When watching Your video I can see two big differences, which could be responsible for the different behaviour:
  1. When You dimension the second angle You are using angular dimensions (blue) while I used a smart dimensio  (violet)
  2. And I am using ST10 while You have ST9
Wolfgang
Thank you! I did it!
As you pointed out, it seems to be the reason why using angular dimensions without using smart dimension did not work.
I do not think that I can still use the variable table yet, but I think that I learned about this method and that I was able to do so.
Thank you very much for telling me politely.
That was really helpful.
Since it is immature, there may be times when you may hit the wall again, but I think I will ask again at that time.
I think that I will let the question from me end at this question if there is no problem in particular.
I'm really thankful to you.
regards.
(view in My Videos)
